OMG!! Have u guyz seen this muffler??!!
D7zul
2,697
848
Shah Alam
While i'm searching for an exhaust system for my beloved 'new' KE70, i stumble upon this muffler..
and I would definitely put this on my KE70 for daily driving & weekend drifting..
anyone have seen this in Malaysia?
Supra_Fanatics
20,673
3,998
Wow...someone Patented it..looks cool and unique...not sure if it is good :top:
D7zul
2,697
848
Shah Alam
what's not good about it?
it's a straight muffler + an S muffler built into 1.. juz need to screw/unscrew to switch from 1 to another..
:biggrin:
lonelylilpig
832
33
How is this muffler works ? I doesn't look like those valve operated muffler like Type Rs or super cars !?
pcmoddingmy
1,147
101
www.pcmoddingmy.com
I think most DC5 or even FD2R are using this type of "switching muffler" as their stock setup. I recon, Honda's design is much more better as the muffler will switch to straight flow during high-rev as there's a built-in valve inside the muffler itself.
But for KE70, just drop in a 20v with open ITB and fit a loudass muffler...drifutooo... that's the way you should be doing it :P
mADmAN
1,840
547
the cap have to remove manually via screws? very the leceh....if u rempiting then got road block...dun tell me wanna stop by the side of the road, get out, n pasang the cap?
this is better:
‪Varex remote control muffler.‬‏ - YouTube
and most people here either use the Aerospeed Exhaust Valve Controller which limits the amount of gasses n noise
or use a throttle body which redirects the exhaust to a secondary pipe which flows out a silent muffler)
varex, aerospeed, and tb can be controlled on the fly from inside the cabin itself...no need to manually close the loud exhaust
D7zul
2,697
848
Shah Alam
this is better:
u got a point there.. i think this muffler for the low budget guyz like me :biggrin:
need to plug the red thingy & screw to get S muffler..
unscrew for straight..
wats the price like?
dunno.. didn't find it in Malaysia
mADmAN
1,840
547
low budget??
i think its better to expect those type of mufflers to be very expensive...
u want cheap....start researching on the TB setup...even a faulty TB can be used..as long as the butterfly can open and close properly.
D7zul
2,697
848
Shah Alam
low budget??
if we got some1 who can copycat this muffler, sure cheap one..:biggrin:
Malaysia Boleh :driver:
:biggrin:
---------- Post added at 06:31 PM ---------- 6 hour anti-bump limit - Previous post was at 06:27 PM ----------
hahaha.. i dont like pencemaran bunyi..
:biggrin:
alantjw
1,566
128
i want the X force....
max327
44
27
N/A
since you mentioned "low budget", may be you can find an old muffler, go to the ah pek shop for some welding and get the similar thing.
i know what you are thinking,
you wanna keep it as S-flow when driving on the street, low profile...
then when hit the car park for drifting, let all hell break loose...:biggrin:
Veloc
3,234
991
Sabah
Damn that's one nice piece of inovation! I think because it switches from straight to S, and not like those with a butterfly valve, it will have superior flow...
