Antiroll Bar, Sway Bar
deathzone
373
13
Kota Kinabalu
Pls share! thanks!
1. Can i mod Dc2r or EK9 rear antiroll/ sway bar to my 4 doors civic ek4? Any benefit comparing my stock ek4 smaller sway bar?
2. Which is better to mod for ek4 4doors..... ek9 crossmember set or dc2?
cad843
403
12
3,018
Oita Ken
I asked the same question before to my foreman and he mentioned that ek9 ARB not suitable for EK 4 door / EJ Chasis and might "koyak" your chasis but dunno whether true or not. So now Im using ek4 ARB at my EK3 4 door chasis. About DC2 .. Im not so sure
deathzone
373
13
Kota Kinabalu
In fact i also read in some forum that ek4 swaybar is more suitable for 4doors sedan compare to type r but need opinion from u guys here before i change anything.
g4i8y0t
1,216
330
683
Kedah
I'm gonna copy & paste some useful info I got from d-series.org:
The only EK Civics that came with rear sway bars are the Civic Type R and the Civic Si, although all EK Civics have the same (Lower Control Arms) LCAs and thusly all accept a rear sway. The Si sway bar endlinks need to be used in conjunction with any factory and most aftermarket sway bars. To make it easy, even the DC2 Integra sway bars will require the Si endlinks, available at any Honda dealer.
When adding a rear sway to a US market Civic, anything over the size of the Si rear sway should have suitable "subframe" reinforcement. The factory Civic Type R which runs a larger-than-Si sway bar has factory bracing to prevent rear suspension damage. The price of a large sway bar's benefit manifests as the sway bar is counteracting the LCA, the sway bar twists. As it twists, the sway bar exerts force upon the subframe and tries to pull itself away from the car. Without any reinforcement for a larger bar, the sway bar will pull itself away from the car on extreme movements and possibly tear away its mounts from the rear subframe. If you are planning on a larger-than-Si rear sway (including the Civic Type R and all DC2 Integra), please consider reinforcement options from Beaks or A-Spec-Racing.
Compatible factory sway bar sizing:
Front:
1992-1995 Civic Si: 21mm
1992-1995 Civic EX: 21mm
1994-1997 del Sol DOHC: 24mm
1996-2000 Civic EX: 22mm
1996-2000 Civic HX: 22mm
1999-2000 Civic Si: 26mm
1997-2000 Civic Type R: 26mm
1994-2001 Integra LS: 22mm
1994-2001 Integra GSR: 24mm
1996-2001 Integra Type R: 24mm
Rear:
1992-1995 Civic EX: 13mm
1994-1997 del Sol DOHC: 15mm
1999-2000 Civic Si: 13mm
1997-2000 Civic Type R: 22mm
1994-1999 Integra LS: 13mm
2000-2001 Integra LS: 14mm
1994-2001 Integra GSR: 14mm
1996-2001 Integra Type R: 23mm (JDM) 22mm (USDM)
All info is from JDMUniverse.com originally written by user: phunhaus
---------- Post added at 07:50 PM ---------- 6 hour anti-bump limit - Previous post was at 07:39 PM ----------
rear subframe damage looks like this:
not a pleasant sight.. :help:
shiroitenshi
3,676
170
Yeah. The ek9 arb is known to tear out the rear subframe. I'm using a 23mm ARB Although the eg has never suffered torn subframe from bigger arb, I decided to play it safe and use the ASR subframe brace. It didn't exactly fit 100% since out of the six holes, one was off by 2mm, and I had to mod it to fit. There's a model for the ek, but I think the ek4 arb is good enough. Don't think there was much bodyroll when I was driving an ek sedan with ek9 shocks and the ek4 ARB. If you feel there is too much body roll, check the arb bushes. If they're loose, that's the source of your problem.
Sil80-13
1,215
44
1,648
I have mod the DC2R rear ARB into my EG dolphin. Is this ok? Or long term it will damange the rear chasis (subframe)? Please advice.
Or is it advisable to install ASR subframe for my EG?
g4i8y0t
1,216
330
683
Kedah
I think cap ayam brace also can, if it's thick enough. sifus please correct me if I'm wrong.
mADmAN
1,840
547
those selling for around RM350 are replicas lor.... can see the diff HERE...ori costs about 7xx-8xx
but they should work well enough to reinforce the subframe.. and they look just as hawt..
---------- Post added at 02:33 PM ---------- 6 hour anti-bump limit - Previous post was at 02:33 PM ----------
mADmAN
1,840
547
@deathzone
how long u using the ASR already?
and wat lower control arms u using?
Globalization is supposed to bring the world closer together by integrating all the different aspects of our lives to function as one big and well-lubricated machine. So logic dictates that a globally designed car would fly off the showroom floors faster than an underground fiber optics cable could send an e-brochure of it your way.
This brings us then to the Chevrolet Cruze, a truly global car and the model...
