News
New Ferrari Roma in Malaysia now – 3.4 sec / 620ps V8 / 8-DCT
3. 4 secs / 620ps / 760nm / 3.9L V8 twin scroll twin turbo / 7,500rpm / 1,472kg / 8 speed DCT / 320km+ / RM986K before tax and options
Yet another new Ferrari arrives KL but this time, the mood is different. It is the Prancing Horse’s latest GT entry, featuring a 620ps V8 twin turbo up front but mounted in the middle, then paired with a very new, 8 speed dual clutch box.
8 Speed Dual Clutch Box
The new 8-DCT box is 6kg lighter than the current 7-speed version and apparently, it shifts smoother and quicker via new low viscosity oil delivery with a dry-sump system, improving fluid dynamic efficiency which is what makes the new Ferrari 8-DCT either more responsive at full volume or seamless in the city.
This DCT box is taken from Ferrari’s new SF90 Stradale PHEV and the biggest changes made to suit the non-hybrid Roma are longer gear ratios to match the GT mood and the inclusion of a reverse gear as the electric motor assisted SF90 didn’t need a mechanical one. The clutch module is also new, despite being shrunk 20% smaller, it is now able to handle 35% more torque.
The Roma celebrates the good old times of the 50s and proportions wise, it is inspired by the silhouette of grand touring legends 250 GT and GT 2+2 with the mile long bonnet, front engine RWD configuration.
Power and Platform
As with the base platform, its 3.9L 620ps V8 twin turbo engine is borrowed from the Portofino and further tuned. But the Roma is pure GT, faster and intended to fill the gap between the Portofino and the F8.
Every new boosted Ferrari promises to be lag free and instantaneous. The Roma is no different, and apart from employing twin scroll turbocharging, with Variable Boost Management which unlocks more power as the transmission gear number climbs, also a smaller flat plane crankshaft among other mechanical components used to quicken engine response.
New Cockpit
The cockpit’s new crown jewel is non other than Ferrari’s brand new cinematic instrument cluster. It is a single piece 16″ hi-def curved screen with a brilliant blue hued UI that could have come straight out of Avengers. it is completely personalizable, eg tactical central tacho with split screen vitals or full screen nav for city recon, the choice is yours, Tony.
Ferrari’s all-in-one steering wheel is brand new as you can tell from the backlit markings beneath the smoked, glass-like surfaces. It’s received further digitization with multi touch control buttons, even haptic controls and a touchpad on the right spoke for nav control. Driving mode selector thankfully, has been kept manual.
The Ferrari Roma coupé will be here for private viewing (by appointment) until 29th June 2020.
FERRARI ROMA TECHNICAL SPECIFICATIONS
ENGINE
  • Type V8 – 90° turbo
  • Overall displacement 3855 cc
  • Bore and stroke 86.5 mm x 82 mm
  • Maximum power output* 456 kW (620 cv) at 5750 – 7500 rpm
  • Maximum torque 760 Nm at 3000 – 5750 rpm
  • Max. engine speed 7500 rpm
  • Compression ratio 9.45:1
DIMENSIONS AND WEIGHT
  • Length 4656 mm
  • Width 1974 mm
  • Height 1301 mm
  • Wheelbase 2670 mm
  • Front track 1652 mm
  • Rear track 1679 mm
  • Kerb weight** 1570 kg
  • Dry weight** 1472 kg
  • Dry weight/power 2.37 kg/cv
  • Boot capacity 272 litres/ 345 litres
  • Fuel tank capacity 80 l
TYRES AND WHEELS
  • Front 245/35 ZR20; 8J x 20”
  • Rear 285/35 ZR20; 10J x 20”
BRAKES
  • Front 390 mm x 34 mm
  • Rear 360 mm x 32 mm
TRANSMISSION AND GEARBOX
  • 8-speed F1 dual-clutch gearbox
Electronic controls EPS, VDC, ABS with EBD, F1-TCS, E-Diff3, SSC 6.0, FDE, SCM-E Frs
Performance
  • 0-100 km/h 3.4 s
  • 0-200 km/h 9.3 s
  • Max. speed > 320 km/h
15,231
6,374
that is a GORGEOUS car.. goddamn. You'll need a front and back camera to park though. Those lips loo expensive
Reactions: Tom
ixeo
ixeo
4,771
3,077
KL, Malaysia
Why do I get some Aston vibes from the silhouette? Is it just me?
Reactions: Tom
Tom
TIMETOATTACK
Tom
TIMETOATTACK
5,506
3,198
yeah you're not alone, a lot of people say that especially on youtube
but it sure looks much better in real life
