BMWEngine UpgradesNewsVideos
Revealed: BMW M3 GTS – The Most Extreme E92 Yet!
If you have been following these digital pages for the past few weeks then I’m hoping you remember the story of the mysterious BMW M3 with the massive wing testing at the Nurburgring. There were speculations of it possibly being a mule to test new powerplants, there was also talk of it being the revival of the CSL, but it ultimately turned out to be this beauty, the M3 GTS – the most extreme E92 to date.
BMW M3 GTS (10)BMW M3 GTSBMW M3 GTS (1)BMW M3 GTS (11)BMW M3 GTS (2)BMW M3 GTS (3)
BMW M3 GTS (2)
The M3 GTS is powered by a 4.4-liter V8 that is based on the 4.0-liter engine that powers the standard M3. With the increased displacement, power naturally rises and the GTS gains 36hp more over the standard M3. Power is transferred to the tarmac via a 7-speed M dual clutch transmission (M-DCT) with adapted shift characteristics.
BMW M3 GTS (8)
A KW sticker was spotted on the test car that ran the ‘Ring, giving raise to speculation that the German suspension specialist could have a hand in the suspension department but BMW made no mention of this in their press release. However, the GTS gets threaded suspension which is able to adjust both compression and rebound, while the rear axle support is said to be bolted in place.
BMW M3 GTS (5)
Another thing that stuck out like a sore thumb in the test car was the massive rear wing but it has been credited with generating high levels of downforce. Both the rear wing and front splitters are adjustable for increased cornering precision and handling.
BMW M3 GTS (9)
In its quest to beat the E46 M3 CSL’s Nurburgring lap time, the GTS has naturally undergone a heavy diet program consisting of carbon-fiber and other light weight material that includes light body-contoured seats, a new titanium rear silencer, the removal of air conditioning and the rear seats. The GTS weighs in at 1490kg.
BMW M3 GTS (10)
Indispensable for safety reasons: the lightweight construction body has been prepared for installation of the 6-point seatbelt included for use on the race track. There are also mounts for the roll-over protective structure bolted on from the B column. A fire extinguisher and a battery master switch/emergency shut-off preparation do not make the car lighter either – but safer.
BMW M3 GTS (11)
BMW will only manufacture the M3 GTS to order and sell it at about €115,000 (US$170,614) per unit. German deliveries begin in May 2010 while other countries are scheduled for mid 2010. Read on below for more information from the official press release.
BMW M3 GTS (7)BMW M3 GTS (9)BMW M3 GTS (5)BMW M3 GTS (4)BMW M3 GTS (8)BMW M3 GTS (6)
Press Release
Even when you see it from a distance, you are instantly electrified. As a BMW M enthusiast, every step you take towards the orange painted concept vehicle of the BMW M3 GTS with its numerous matt black applications raises your adrenaline level a little more.
Exclusive 19-inch wheels with ample 225/35 tyres at the front and 285/30 at the rear catch your eye.
All this is certainly nice looking and sensible, but what you glimpse through the spokes of the aluminium wheel rims is even more exciting: a generously sized fixed caliper brake system with six pistons at the front and four at the rear.
The wheels almost fill out the wheel arches, but if you look closely you discover the next highlight. Yellow springs with a small M logo provide the crucial clue: a threaded suspension, adjustable in compression and rebound. “The rear axle support is bolted in place,” adds the responsible engineer.
The expert will also spot the adjustable front splitter and rear wing. One thing is clear: this car is serious stuff. Not only can a high level of downforce be generated but it also precisely adjustable at front and rear. Fast bends can look forward to welcoming the BMW M3 GTS – but they won’t get to see it for long.
Which brings us to the next question: what does it weigh?
“The serial production BMW M3 is already weight-optimised with a whole range of measures reserved for the BMW M3 CSL in the last model – the striking carbon lightweight roof, for example.”
So the engineers had to get back to work again to come up with more. Light body-contoured seats are a must.
A cluster of lightweight construction measures such as optimisation of the insulation, the use of lightweight parts in the interior, the use of Macrolon for the car’s windows in the back, the lack of air conditioning, navigation and radio and the entire rear seat also gets the scales the down.
And the new titanium rear silencer not only looks great and contributes to the thrilling sound of the BMW M3 GTS, it is also much lighter than its serial production counterpart.
So the BMW M3 GTS concept vehicle puts the scales up to around 1490 kilograms – causing the engineer to give an appreciative nod.
And the drivetrain? The heart of the BMW M3 GTS?
The car is fitted with a 7-speed M dual clutch transmission with adapted shift characteristics. But an absolute highlight is to be found under the bonnet. Exclusively for the BMW M3 GTS, the engine builders of BMW M – recent winners of the Engine of the Year Award once again – have developed a power unit based on the M high-performance engine of the current BMW M3: with a capacity of 4.4 litres and an output of some 450 bhp, it will catapult the light BMW M3 GTS into a whole new sphere.
After all, the aim is to clearly beat the lap time of the legendary M3 CSL on the Nürburgring Nordschleife. And test runs certainly give grounds for optimism.
The BMW M3 GTS is manufactured to order on an individual basis at the BMW M production workshops.
The price of the BMW M3 GTS with the features shown is expected to be EUR 115,000.- for delivery in Germany, including 19% VAT.
The first vehicles are due to be supplied in May 2010. For technical reasons relating to registration, the first vehicles to be produced will be those for individual registration in Germany. According to current planning, registrations in other countries will be possible from summer 2010.
If you are interested in the BMW M3 GTS, we recommend registering for our competition, in which you can win a place to attend the exclusive vehicle presentation.
K
  • K
    kannasai
  • Nov 5, 2009
same style from 2006 Porsche 911 GT3 RS (997)? o.O???
orange ride, black wheels, semi roll-cage and back rear wing.. hmm..
T
  • T
    teamsleepnine
  • Nov 6, 2009
yes exactly!!!,the styling is directly towords th 997 rs...
and orange doesnt go well with bm,the on bright fancy colours that i can only think of(that go well with bm)is yellow(like e36)and red.
thats just my opinion!!
T
